Hello, I have a 2002 Polaris Sportsman 700.
It is very hard to shift manually! Does anyone have any idea would is wrong? It still runs great when you get it in gear. I appreciate the help!
Jason
Is it hard to shift when not running as well as running? If not then an idle adjustment may be all that's needed. If so, then I would be looking at the shift linkage in the transmission.
Hey man I appreciate the help. I will look into the shift linkage. It is hard to shift when it is both on and off.
Welcome to the board!
