Got into 4 wheeling last fall. Looking for some tech advice on starter grinding issue on my 2008 Sportsman 400 HO. thanks !!
Welcome aboard!
grind it or fix it
If it grinding you better fix it. sounds like its time for a starter. you dont want to tear up anything. just pull the starter and see what the gear on the end looks like and also check the flywheel for dammage. you can also run the starter with it removed to see if it is working right.
