HID Light Install on Scrambler
This conversion will work with any hi/lo bulb combo that Polaris runs. I picked up a 35w Hid kit 5000k on ebay for $27 in the 880 series bulb single beam.
Before you rush off to ebay and buy your bulbs understand that you need to cut apart the factory 4030061 bulb to make these work along with cutting your factory headlight connector off.
I pulled the bulb from plastic housing then broke all the plastic tabs inside the circle with a screw driver, next drill a hole from the outside of the bulb case, open up the hole with a carbide bit on a dermel to the inside opening.
Last step slide the hid into the bulb case then apply jb weld from the backside to hold the two in place
