1 - 11 of 11 Posts
though i would post a video of my low beams after installing some cheap HID's. they are temporary, i will replace them with something better if they crap out but i wanted to see if i would like them. needless to say i am looking for a ballast and bulb for the high beam lol. install is painless, any kit will be plug and play as long as you get it for the right bulb. forgot to take pics of the install but they are tucked up under the inspection cover for the radiator.
ill be posting the video of my $10 10watt led back up light soon.
Do these need to "warm up" when the ambient temperature gets really cold? When its cold out Ive seen that issue with some HID's where they are super dim when initially turned on then they slowly warm up, or else just don't turn on at all. Only curious, looks good bro!!!
ya takes about 45 seconds to reach full output, and about 20 to reach useable output. the video makes it a bit hard to tell because its trying to keep the exposure even.
That's not bad, the ones ive had experience with took a full 2 minutes to warm up.
Discussion Starter · #6 ·
i ordered 5k bulbs, but they look closer to 6k to me. either way they are ok, i just wouldn't go any higher in snow conditions.
Discussion Starter · #8 ·
this gives you a better idea what they look like when you are actually using them. i was testing out my camera while i was checking to make sure my plow was set high enough to not take a bunch of gravel with it.
That's not bad at all. Brighter than I expected.
1 - 11 of 11 Posts
