I just finished up installing my clutch kit from Ryan on here. QSC did their homework on these kits. It pulls so much harder then factory that it's not even funny. Really easy install and the best mod so far on my 13 850xp. Just wanted to give a big shout out to Ryan for all your help.
I feel the stock clutching is kinda soft. I'd like something a bit more aggressive. Can explain your thoughts on the kit? I'd like to know why you like it so much. Thanks, Scott
Yes the stock clutching is way soft and your losing out on so much bottom and midrange that you have to change something. With this kit it really wakes up your bottom and midrange, now you do lose out on some top end speed like 6-7mph but I don't need to go 80 anyways. It also eliminates the harsh reverse engagment that they are known for. Before I installed my kit I could stand on the throttle from a dead stop and it would in my mind slowly engage untill you were doing 10-15mph and then really hook up and go, even at 30-35 it was way soft. Now with this kit if you cob the gas it will stand straight up in the air and the midrange is neck snapping different. I would highly recommend a QSC kit to anyone from the hard core mudder to an average joe like myself just looking to get a little extra bang from your buck.
Comes with a couple shims for the primary spring so you can adjust from 1600, 1800, 2000, or 2200 depending on your preference and riding conditions and style. Most I recommend no shims which is the 1600 engagement. I am running the thin one in mine and still smooth but helps with my really heavy tires.
Yeah they make a huge difference. Even with my heavy Grippers, and my GF on the back, I can stand it up in hi range no problem. And now in gummy mud, you barely have to tap the gas to get all 4 wheels throwing mud. With the stock clutching, it would take about half throttle to get my wheels spinning in mud in low range.
I went with the thick washer (2000 rpm engagement), and kinda wish I would have gone with the thin one instead. Granted once you get used to it, the higher engagement isn't so bad.
Need to fix a few things first, unfortunately no extra $ to spend on it at the moment. Perhaps after Christmas I'll be able to start working on it again. :yup: Once I spend $500 on parts to fix the few things that are wrong with it I plan on QSC kit, then new wheels and tires! :beerchug:
I got a 2006 Sportsman 500 HO EFI, I have put a big gun exhaust, Big gun fuel controller and K&N air filter. I am currently running 25" Mud Wolf tires. I would really like to get a QSC Clutch kit but I hear that they are really only for larger tires.... Will this kit work well with my current 25" tires? Also will I be able to install this myself, will I need any special tools or do I need to take it to the dealer? Thanks
P.S. anyone have any knowledge on how to properly tune my bike with the fuel contorller?
$230 shipped to your door I believe. There's no reason to wait to improve your stock machine just do it. It is very simple to install and really requires no special tools other then some creative thinking for the secondary, ready rod and some washers.
Just picked up a 2016 today. I have been a dirt bike and snowmobile guy, this is my first ATV that I have bought.
What are you supposed to do with the gaping hole left from removing the rear seat? Is there a cover or box or something that can be had to fill the hole in? I was thinking the...
I did some searches and could not find what I w as looking for.
I just bought a 2019 570 Sportsman, and would like to control max speed when certain people are riding the bike.
is there anything I can do?
Any after market products that would accomplish this?
thanks
Hello, I am glad to find this forum about Polaris rides, thanks for having me here!
I have a 2004 700 Sportsman Carbureted that is Blue and Silver with under 1,000 miles on it! I use it as a tool on my property to plow, get firewood and my wife to ride once in awhile.
The light bulbs are...
Bought this one new and remembering it took all day to replace the battery the 1st time, now I need to do it again, X2s have the battery under the gas tank and in front of the engine and it's a nightmare just to change it out. Has anyone found a easier way to change it our?
