Do you have a test light to see if you have power at the winch when you hit the in/out switch? If so check that first. If you have power to the winch and its not working it may be faulty, make sure winch is not in free spool mode, positive and negative are hooked up properly. If no power at the winch work your way back checking in/out switch, fuses, connections ect...
