1 - 16 of 16 Posts
Somebody put that on there to absorb the vibration in the shift lever
Reactions: MrEd
That's what I figured - I'm wondering if the zip ties that aren't actually on the hose are contributing to the rattling I'm hearing when driving. All of my exhaust heat shields seem secure.
those zip ties are keeping it from sliding out of position.
Sounds like they never solved the rattle.
Just ride it and pay no attention to rattles unless they get louder or change in pitch... Its a Polaris lol
Discussion Starter · #8 ·
I am incredibly OCD about getting rid of noises if I can. It's like a puzzle sitting unfinished on my table :)
Understood, when our group has a new rider they have a ton of questions.
They tend to panic that some is failing, those of us on old bikes are like "nah thats normal" haha
One thing I will say, is do not ignore things like the bike being hard to shift or fluid change intervals and you will be fine.
Discussion Starter · #13 ·
Thanks! I changed all my fluids right away (they were filthy - bike had 45 hours and I'm pretty sure nothing had been changed), and got my first greasing done. Now it's the littler things when I have free time. I think my rattling might actually be coming from the plastic on the right side of the bike hitting part of the exhaust heat shield - it looks like there is some foam installed there but it has worn thin. Is there a standard type of adhesive foam people use for parts that might hit?
Discussion Starter · #15 ·
I've had luck with a spray adhesive and cleaning the spot really well with a goof off or oops type product.
Surface prep is key. Also check for broken body clips, the plastic push style, they can get loose over time.
I keep this kit that I got from Amazon.
I ordered the clip puller tool from Quad Logic and it came with a bag full of clips. I do have a couple that seem loose. Do you have a recommended foam to replace the stuff that seems worn with?
1 - 16 of 16 Posts
