Indicator flashes hot when ATV is not hot. Ride very short time and especially if radiator gets wet and Hot/overheat indicated. Fan runs sometime other times does not. Fan works as I removed and tested. Has coolant. Is there a thermostat or indicator that could be messed up? How do I check. Now fan out and turn key on w/o starting and HOT.
