1 - 2 of 2 Posts
I have a 2x4 400 94 sportsman and i have no spark. I have new tension coil and would like to know is it possible to run fused hotwire to the tension coil to make her run?
Can I bypass all the brain and voltage regulator .?
It can be done, but I don't recommend it. The black wires in the cluster F*** of wires in the front end are all the safety loops and kill switches. If you unplug them you will bypass it all. Try that before you go cutting and splicing a bunch of stuff for nothing.
1 - 2 of 2 Posts
