1 - 12 of 12 Posts
before you need to drain the oils
I know the rear diff breather goes up to the pod. I think the front one goes up to the rad. But you have intakes for your engine and cvt that are a bigger concern. Air intake goes below the gas tank and the cvt is only safe to about halfway up your side panel.
ok thanks for the info...I only had it up to the floor boards and had to winch it out in ice cold snow melt
Sure
sounds good - officially the manual says the upper limit is the floorboards. you know the lawyers, engineers and others negotiated on that statement. So it can go a little deeper, safely, but I suppose for really deep stuff needs piping. I only go to the boards too...
As deep as ur pockets!
That is by far the best answer yet.
Option 1: You pay up front to modify your machine to go in the water.
Option 2: You pay in the end to fix it after you have done something stupid.
Option 3: Stay out of the water and mud until you have read Option 1.
Well said BP!
I went in 2 feet of water in a large mud hole with no problems at all! I am amazed at how well it performed.
I certainly hope so
I like to go balls deep on a regular basis. She'll be fine up to there.
I have actually put mine in water up to the seat several times and no problems yet just stay in the water! but be careful because I have gotten my clutch wet more than once and one time I almost didnt make it out of the water because the belt was slipping.
1 - 12 of 12 Posts
