Trying to replace the mechanical water pump seal on my 1995 scrambler 400 two stroke. Got diagram off of here wich shows the water pump behimd the aluminum sidecover. Iam calling it sidecover.... It is the aluminum panel on the right side of the motor that houses the flywheel.. Here is what i have done.. removed pull start housing, removed the flywheel, removed the 3 machine screws holding electronix field gizmo under the flywheel, all the 12mm bolts and the 10mm ones as well... Wjat else do i need to removed to get this panel off. I am not really seeig anymore bolts????
