Got my stator.removed from the third caae and set aside
i need to remove the third case now and dont know where to inhook the stator wires. Wires run through.engine up left side, and up under the headlight somewhere
i dont see where it unplugs at all.. Or do you have to cut and resplice????? its a 1995 scrambler 400 4x4 two stroke
Should be 4 or 5 inline connectors under the front plastics near the fuel tank. By the way Nate it would be a lot easier for those trying to help if you would combine all your threads together. Just pick 1 thread and run with it instead of starting a new thread for each question. Just a thought, Buddy.
thanks for the info
Sorry.. I know my posts are sporadic but i hink i got it now. I work for the railroad so i am in and out driving trains, so i work on it here or there and look to solve problems as i find them
