I have fox podium shocks on my predator and i not sure how to adjust the rear shock it looks like it is as loose as it can go and it needs to be tightened
I don't mean to hijack a thread, but I have an 03 and was wondering about the front shocks. Is there any adjustments besides the preload on them?On top of the spring is the adjustment.Loosen the jam nut and then turn the adjustment ring clockwise(I think)to stiffen it.Dont forget to tighten the jam nut when you get it adjusted.It should also have a screw for compression damping and rebound damping on the reservoir if you need to do that.Should be the same for the front.
