my 1995 polaris sportsman 400 (water cooled) i just got ha shad the wiring boogered wiht. For one, the fan comes on constantly when you turn the key on.. I can assume the thermo switch off the radiator is bad, but i would like to test it first.. Is it as easy as putting a test light on it to see if it has power whent he motor is warm????? Do these swithces go bad often???
Also the headlights ar enot working and i have found some ground wires that are loose. Does anyone have a wiring diagram of the panel below the headlights/ behind the oil tank/ unde rtthe cover that has the terminals for wire hookups???? i think it is not in order
