I'm going to be adding a 2" highlifter lift with rear axle bar kit and upgrading to 28" Zillas on 14" Ss212's with a qsc clutch kit in the very near future. How much additional lift should I expect with this set up?
Discussion Starter #2
Should add fair bit of clearance.Why did you chose 14" rims?
How does your 500 handle the 27"? Would you have a pic handy?
27's have been great but I wouldn't go any larger without a lift and or clutch kit.
The Zillas run on the small side so the 28's will likely measure closer to 27. 2" lift will probably really get you about 1.5" of actual clearance in the center, nothing by the wheels.
