1 - 14 of 14 Posts
Purchased a ngk iridium for my sportsman and was wondering how to get the plug out, it doesn't look too easy, do I have to remove the gas tank? I'm pretty sure the plug that is in it now is the one from the factory
Also does anyone know the ngk replacement part number for the plug wire, the Polaris number is 3084980
Sent from my SGH-I757M using Tapatalk
You have to remove the gas tank to get to it. The plug wire is nothing special. You can get it at any small engine shop, or the dealer likely has it in bulk. The wire just unscrews from the coil and the cap just screws onto the wire as well.
One word of advice, use compressed air to blow out hole for spark plug before you remove it, any mud or debri that's in the hole will fall into motor when u take plug out, Shouldn't have to remove tank, its tight but can be done from right side, remove inspection panel.
Can you not get the factory tool in from the right hand side and slip it into the hole and loosen it, then unwind by hand? I have never taken my gas tank off to remove a plug, but I have never owned a 01 400 but have an 01 500.
What Russ said. ^ Take the right side panel off and it's not bad at all.
Never removed my gas tank, just remove right side panel.
Discussion Starter · #9 ·
Ok that's good news, has anyone tried am iridium plug? Will they make any difference at all
Not tried a iridium plug. Been running the stock Ngk .
I run Iridiums, seem to make it start better, cant say for sure if there is any performance gain but im not switching back.
Discussion Starter · #12 ·
I have no problem starting, even after sitting for a few weeks in freezing temperatures it starts the first flick of the button, but I also heard it improves idle and throttle response
x2 on using the factory tool. Only thing that came in the toolkit for my 500 that was worth anything.
1 - 14 of 14 Posts
