Currently have 110 rear bolt pattern and would like to have 4x156 to match the front so that I can get wheels that look the same. The ones I have now look very similar but I notice the little things. I don't mind if it's a bolt on adapter, but the only adapters I have seen go from 156 to 110. I thought about putting a 156 rear hub on the solid axle but don't know if it can be done or if anyone has even tried.
This is on a 99 Sportsman 500 if that matters
Wes
Have you looked at new hubs? A newer year may retro fit neting you the same lug pattern.
Only other thing I can think is adapter spacers.
I have not looked to in depth on it, but have thought about it. Right now I'm just trying to get this thing to run. Just trying to plan out all that I want to do to it.
