Hi everybody,
I know there is a zerk on the prop shaft, just behind the right foot well. I can see it but I cannot get my grease gun in there. Should I remove the foot well to do the greasing?
Move the ATV until the zerk is pointing in a direction where you can get the grease gun on it by coming in from the real wheel well. I eventually drilled a hole through the foot well that lined up with the zerk, this way I can frequently grease it with ease.
You can remove the footwell for added space but if you move the shaft like previously suggested, you can find a position that works.
Mark
