Car wash soap and a soft brush, dry and spray with maxima sc1Great video and thanks.
However do you have a recommendation for cleaning products for a ATV or UTV? I just got the Sportsman 850 SP in sunset red and would like to keep it looking like new as long as I can. I just hosed it off today with a garden hose and although most of the dirt/dust washed off, a lot was left behind which I used a towel to wipe the rest off.
Dave
Dave
Dave
^This is what I do^ except I use the Cover All instead of sc1 because I can pick it up at O'Reilly's instead of having to order it like sc1. Either one works great and helps the mud from sticking on your next ride.Car wash soap and a soft brush, dry and spray with maxima sc1
Sure does, and it beats rubbing/wiping wax all over too.Great video and thanks.
Dave
^This is what I do^ except I use the Cover All instead of sc1 because I can pick it up at O'Reilly's instead of having to order it like sc1. Either one works great and helps the mud from sticking on your next ride.[/QUOTE]Car wash soap and a soft brush, dry and spray with maxima sc1
Where'd you get a gallon can? That sounds like a better way to go about it.Plus they make cover all in a gallon jug. SC1 you have to purchase in a aerosol can only. I pour coverall into a spray bottle and it applies it much, much better than wasting half of it into the air like you would with a spray nozzle on a aerosol can.
Ole Nasty...I picked up a can of the Cover All since I will be detailing my bike soon. I still have to get in and wash everything under the plastics and such. My main question/concern is this...what all do you spray that Cover All on? Is there anything I should avoid spraying? I don't want this to wind up like the time I used plastic restoring spray and used it on a plastic/rubber part near my window that basically turned to gum after being sprayed.Great video and thanks.
Dave
