1 - 1 of 1 Posts
Step one- remove the two clips from the bolts on the rear rotor
Step Two- remove two bolts that hold the brake pads on (not allen key bolts they do not need to be removed)
Step three-Remove caliper by removing the other two bolts
Step four compress the piston with your hands or a c-clamp
put new brake pads on
Same thing goes for the front pads
The bolts are very hard to get at so use a socket and a extension (i think its a 13mm deep socket)
The bolts to remove the pads are the top bolts on the caliper, the lower ones remove the caliper.
1 - 1 of 1 Posts
