1 - 2 of 2 Posts
I was told that to fix bearing problems, I will have to replace the whole hub on each tire. They want $107 per hub. Is there any places or websites you guys can suggest to get them cheaper? Let me know thanks
I have a 2003 Sportsman 600twin
You shouldn't have to replace the hub if your doing bearings in the front strut unless they have broken on the backside the only way to tell is by removimg the hub.Remove the caliper and remove cotter pin and big nut on the cv shaft.Should pull right out of the strut.Theres an earlier post on how to remove bearings.
J.R
1 - 2 of 2 Posts
