I recently purchased a 2001 500 magnum 4x4 and someone has changed the front right hub strut to a 2wd one. I found the replacement parts on ebay but stumbled on a 93-94ish 4x4 explorer trailboss or ? The current owner doesn't know the year or size. In the pics he sent the hub struts look very similar but I know they have different part numbers. Will or can the be made to work on my 500?
From the Polaris cross reference, it does not look like the early unit will work properly. Here is a list of machines that use the same part number for the front strut. Looks like everything 4x4 from 99 thru 2001 used the same front strut. This is just a part number search, so if they made a change in the part, even a small one, the part number would have changed too. I know there are a number of struts on Ebay. You should be able to find what you need.
2001 ATV MAGNUM 500 FRONT STRUT - A01CD50AA (4959905990B007)
2001 ATV 500 MAGNUM 500 HDS FRONT STRUT - A01CD50AA (4959905990B007)
2001 ATV SPORTSMAN 500 DUSE FRONT STRUT - A01CH50AD (4959905990B007)
2001 ATV SPORTSMAN 6X6 FRONT STRUT - A01CL50AA (4959905990B007)
2001 ATV INT'L BIG BOSS 6X6 FRONT STRUT - A01CL50AA (4959905990B007)
2000 ATV XPLORER FRONT STRUT - A00AG25CA (4954865486B001)
2000 ATV SCRAMBLER 400 FRONT STRUT - A00BG38CA (4954855485B006)
2000 ATV SCRAMBLER 500 FRONT STRUT - A00BG50AA (4954855485B006)
2000 ATV MAGNUM 325 4X4 FRONT STRUT - A00CD32AA (4949304930B005)
2000 ATV MAGNUM 325 4X4 FRONT STRUT - A00CD32CA (4949304930B005)
2000 ATV 325 MAGNUM 4X4 HDS FRONT STRUT - A00CD32FA (4949304930B005)
2000 ATV 325 MAGNUM 4X4 HDS II FRONT STRUT - A00CD32FB (4949304930B005)
2000 ATV MAGNUM 500 FRONT STRUT - A00CD50AA (4949304930B005)
2000 ATV MAGNUM 500 EB FRONT STRUT - A00CD50AA (4949304930B005)
2000 ATV 500 MAGNUM 4X4, HDS FRONT STRUT - A00CD50AA (4949304930B005)
2000 ATV 500 MAGNUM 4X4, HDS II FRONT STRUT - A00CD50AA (4949304930B005)
2000 ATV XPLORER 400 FRONT STRUT - A00CG38CA (4949304930B005)
2000 ATV SPORTSMAN 335 FRONT STRUT - A00CH33AA (4959905990B007)
2000 ATV SPORTSMAN 335 FRONT STRUT - A00CH33AC (4959905990B007)
2000 ATV DIESEL FRONT STRUT - A00CH46CA (4954785478B005)
2000 ATV SPORTSMAN 500 FRONT STRUT - A00CH50AA (4959905990B007)
2000 ATV SPORTSMAN 500 RSE FRONT STRUT - A00CH50AA (4959905990B007)
2000 ATV XPEDITION 325 FRONT STRUT - A00CK32AA (4959905990B007)
2000 ATV XPEDITION 425 FRONT STRUT - A00CK42AA (4949304930B005)
2000 ATV SPORTSMAN 6X6 FRONT STRUT - A00CL50AA (4959905990B007)
2000 ATV INT'L BIG BOSS FRONT STRUT - A00CL50AA (4959905990B007)
1999 ATV SCRAMBLER 400 FRONT STRUT - A99BG38CA (4949664966b005)
1999 ATV SCRAMBLER 400 FRONT STRUT - A99BG38CB (4952505250b005)
1999 ATV SCRAMBLER 500 FRONT STRUT - A99BG50AA (4949714971b005)
1999 ATV XPLORER 300 FRONT STRUT - A99CC28CA (4949484948b006)
1999 ATV MAGNUM 500 FRONT STRUT - A99CD50AA (4949254925B005)
1999 ATV XPLORER 400 FRONT STRUT - A99CG38CA (4949634963B003)
1999 ATV SPORTSMAN 335 FRONT STRUT - A99CH33CB (4945964596b007)
1999 ATV SPORTSMAN 335 FRONT STRUT - A99CH33IA (4949884988b007)
I ended up just putting a bid on the eBay parts. Trip was to far for a "maybe/might" work on the parts quad. Plus the only things I could of used was the possibly the hub struts and maybe the tires but he didn't know the size of those either......so for once I think I used my better judgment. ..lol
Probably a good idea. Hope you got a good deal on the machine....You don't say how much of the original parts you have. As I am sure you know, the strut is only a part of it. You can always use the other side to compare to. Hilliard clutch inside the hub, hub is probably different, with the seals and a couple sets of bearings along with the axle shaft.
