Hello everyone,
I am new to the group.
I was gifted this Polaris 425 4x4 from a relative as they didn't have the time to mess with it. I don't know what year model it is. I have another ATV (1986 Honda 250 4trax) and I have NEVER seen or worked on a Polaris engine. Looks like a different animal.
I was told that this ATV was parked for 3 years under a pole shed after it was used last. It has a couple of flats.. I pressure washed about 10 lbs. of dust off of it. I took off the plastic gas tank and pressured washed it, inside and out. Pressure washed the air intake container and, what I called, the rubber snooze after I took it off. The carburetor had a lot of white/chalky chunks in it. The throttle was stuck closed. Took the carburetor off and soaked it in gas overnight. I gave it a thorough cleaning. The throttle valve was stuck, but got it working. The weird "gate valve" that slides up/down works well. Pulled the red spark plug connecter and realized it had been previously broken and taped back together and coil wire was off. I screwed the coil wire back on, taped it back together and plugged it back in. Put everything back together. The wheels would not roll even in neutral. When I pulled it off my truck down the ramps, gravity helped and the wheels finally turned freely. The battery was topped with water and charged for several days, but seems to be dead anyways. The pull start works and there seems to be some good compression. I will need a new battery and coil wire/plug. A couple of wires were completely bare and were just wrapped with electrical tape. I cut them and replaced with jumpers, connectors, an shrink-wrap.
I tried jumping it off with my Honda 4trax. I realized that the starter/selanoid would not energize (when starter button was pushed) unless the lights were turned on. Sounds like an electrical issue. Seemed like my Honda didn't have enough juice to get the starter to fully engage. Have to wait for the new battery and coil wire/plug. I tried using the pull start, but it is very difficult to wake up a sleeping ATV that way. Not rotator cuff friendly. Lol
Attached is a picture of the Polaris.
