Hi Guys,
I have an '03 600 twin that I flipped over on the throttle side and bent the handle bars about 2 inches. The thumb paddle was broken off from the stem that goes into the upper housing. I have managed to superglue the stem back together with the paddle and insert it back into the assembly. There is a spring that came loose and I am not sure if the inner two inner pieces that are keyed are supposed to be aligned or not. My service manual does not show the insides. Can someone help me out and post a picture of theirs, or tell me how it works. Thanks for the help in advance.
yes get a used one on ebay...if its damaged you never know when it may stick open...
