Hi guys, I posted before about my 1996 xplorer 400 needing some engine work. It had antifreeze in the outer case where the flywheel is and also I can move the crank up and down a little. I started asking around and a guy at work had a complete motor that blew a piston and he tore it down and he gave me the whole motor for $20.00. I now have a start at fixing mine. It will probably a winter project. Thanks all for reading.
Sounds like a fun project. Keeps us posted on the build.
i had the same kinda story. luckily the crank and seals were good on the used motor i got, just needed new top end. now the scrambler runs great :) my only regret was not changing the starter bendix while i had it apart. a mistake i wont make again. cheers.
