1 - 10 of 10 Posts
The brakes have been out for a bit on this bike (2002 Sportsman 700) and I just got the last
line I need. The foot brake line was cut so I got a new one and I cannot seem to find where it hooks up to. I think it might be on the rear caliper but I can’t find where at, a video or diagram would be great.
Please Help..
Thanks in advance.
Foot brake operates just the rear brake and has it own master cylinder.
There is two lines on the rear caliper - 8 and 9 - 8 is the hand brake line and 9 is the foot brake line
The line connecting to the center is the rear brake line and the line off to the side is the hand brake
138306
138307
Okay. I found it.. is the foot brake supposed to push in the master cylinder? Because if so I think it’s froze up.
push in the master cylinder??? going to have to elaborate on that.
I mean by what does the foot brake need to push in or anything to make it work? I have to get a new rear caliper before I put fluid though.
Like all hydraulic brake systems, there is a master cylinder cylinder and a slave cylinder (caliper) - the foot pedal acts upon a master cylinder that operates the caliper.
Yes, so on the master cylinder should the foot brake push in any sort of piston or anything to make it send a signal to the caliper?
no its a separate system. although they do share a common point that being the rear caliper. so with the rear brake being depressed there may be some back pressure noticed at the hand brake master.
1 - 10 of 10 Posts
