1 - 2 of 2 Posts
The rear suspension on the 50 is interesting. The engine and trans is not connected to anything except the rear shock. There is a lot of stress put on that little single coil on the rear. The bottom of the rear swing arm that does not swing has broken at the base of the rectangular bracket that goes forward and attached to the rear of the transmission. If everything is not perfect the rear axle ends up being crooked. It is almost like the mounts that the engine hangs from is crooked but they are not. It is really annoying and I am not sure what to do.
I could start off with obtaining a measurement. If there is someone out there that could give me a measurement from the re tranny split joint to the outside of the black lower frame would help to let me know if the frame is bent.
Thanks,
CHip
Welcome to the board!:med:
1 - 2 of 2 Posts
