1 - 1 of 1 Posts
I have recently purchased a 200 scrambler 400..I have put in a new head and piston complete with seals. I have ran into another issue. It over heats but didn't over heat before the piston change. Pulled the casing off for the flywheel and there is this ring on the shaft in front of the seal...It is a copper like color with squareish indents. I was wondering how to pull that off. I checked the water pump it looks brand new. So going to replace the front and back seals...but I can not get this object off the shaft to get the seal back on. If you know how to get it off or need a picture email me and I will send one out right away. I could use someone who knows a lot about the scrambler as not many do. SO no amatures please know what your talking about as I don't :)
1 - 1 of 1 Posts
