ok guys, I have an issue. Heres what happened. I hit the key and started right up after sitting for a couple weeks in 30 degree temps. the second pass down the driveway the winch wouldn't lift the plow and the headlights went dim. turned the headlights off and the winch would work. noticed when I revved it the dash would turn off and come back on and reset or a system check and the headlights would dim. pulled it back in the garage turned it off by the key, now will not do anything when turning the key no lights or sounds. I can still pull start, but with the same issues.... PLEASE HELP!!! cuz its snowing again!!!
