I recently rolled my trail boss 330 on the pavement. Since then, the engine will only run for 3-5 seconds and the ignition kills it. Eng has brand new battery, good oil and pressure. When the engine stalls, i can blip the on/off switch from from kill to run and the engine will continue to run for another 3-5 seconds then stall again. Switch has correct ohm readings. Also, the fan is always on when the battery is connected. What am i missing????????????:aargh4:
Welcome to the board!:med:
