I replaced my ignition switch on my 92 trailboss 4x4 350L. It had bad tumblers and the old key was very worn which made the key hard to get to turn. After I replaced the switch, I can’t get the starter button or the lights to work. The atv will start and run with the pull start. Can anyone help? I’ll attach a picture of the wires coming from/to the ignition switch. I wired it the same as the old starter switch (or so I thought). Which wires connect to which? The four wires coming from the top are coming from the ignition switch
