21 - 23 of 23 Posts
Discussion Starter #21
Yes not much adjustment just trying small increments. Only adjustment was 2 clicks softer on low speed compression and aired tires to 5 psi (7 recommended)
Discussion Starter #22
Power steering felt good, not sure if just breaking in or if a little lower tire pressure helped?
I had a 07grizzly 700with sra rims all around with 30" mudlites..so it was atleast 53" wide..was great in the muck..and it did ok on the trails but was hitting alot of rocks..roots.etc..but it had stock garbage shocks with a 2" lift..but I ride mostly southern Maine and new Hampshire..tight. Rough trails .but I'm guessing with the high end shocks on the scrambler s. Makes it a whole lot better
21 - 23 of 23 Posts
