1 - 20 of 46 Posts
Smile Organism Grass Font Ball
I'm sure if you try to schedule an appointment your dealer is going to tell you that they're backed up 3 to 6 months
First one of these I’ve seen, how long does this usually take?
Yes, my dealer just notified me last night that I can't take delivery of my 2023 570 Premium because of a Polaris "HOLD" they received. Also, my son took delivery of a 450 last week. Looks like I'll be hoofing it this Deer season. So, I will not just hold for 6 months does anyone recommend another manufacturer that is doing a better engineering job?
Font Window Pattern Screenshot Automotive exterior
to the forum
Gas Font Automotive lighting Ball Vehicle registration plate
I just took delivery of a new 2022 Sportsman 570 last Thursday. I also received the same notice on Tuesday.
You got to be kidding me!!
New toy but can't use it.
Went to my dealer today and they hadn't heard about the issue until I arrived.
I sure would like to know where the interference is so I could inspect/fix it and start riding.
to the forum
I checked in with the dealer. They said there is no fix released yet, even if they could get the unit in. Apparently, there are Polaris units with months old recalls with no fix yet. He said he wouldn't even expect anything until 2023 in just basic info from Polaris. Sad.
Polaris can do a buy back on these units ! But of course that’s not expected ! Bad deal !
You meant SHOULD DO a buy back ~~Old Gezzer~~
Reactions: yooper265
It reads like the machine needs some zip ties to hold the wire harness away from the frame and brake line. Ride on.
^^ I agree, personally, with a recall that doesn’t appear to need any new components, I would just fix myself and ride on. It’s pretty likely I’d do a better job/repair then them anyway. Wouldn’t be the first or last time I rerouted/anchored or added chafing protection to a wire harness or cable.
Dealers are swamped with the latest snowmobile recall at the moment. 230,000 units , model years 2015-2023. It's another stop ride recall do to fuel tank ruptures,fire hazard.
It appears that they have the fix for this recall, but the dealers will need to fix the current inventory so they can sell them. Maybe when polaris in done with this recall, sometime in the spring, they will get the fix out for the ATV's
Yep, I wouldn't stop riding the machine because of this, but it sucks for the guy's that can't take delivery of new machine because of this recall.
Find the spot slit a rubber hose and slip it over the wiring harness in the said areas ~~Old Geezer~~
Just bought a new 450 EPS and a new 570 Trail. 450 had all of 3.1 hrs on it when it started flashing “Release Brake” and the check engine light came on. Dealer was going to pick it up and take back to the shop to troubleshoot when they were dropping off my 570 Trail. Polaris put out a recall on both the day I was to receive the 570. I’ve two new Sportsman’s I can’t even get through the break in period with. Not a good look for Polaris right now.
1 - 20 of 46 Posts
