I recently picked up what i believe is an old trail boss. I used the swing arm and front end to build my son a minni sand rail. I am having trouble with the transmission... I can not get it to go in forward gear..there is a solenoid at the shift linkage on top if this is not working will it prevent it from going in forward gear? neutral and reverse work fine.
im pretty sure that in order to get it into high pushing the brake in was needed on the older machines.....just an idea
I think you are right..I wonder if i could hook it up on a toggle switch or just jump the switch to make it work without re-fabricating the braking. to add the switch on the foot control?
you got me thinking dont think that was a electrical thing because when the wheeler was off the brake would allow to go into high...i could be wrong
