1 - 2 of 2 Posts
Hi all, I am new to the forum. I have a 2015 Sportsman 1000 XP and the ATV was bogging, stalling and some random backfires off and on last season. I pressure washed it and let it sit for the season. This year it will not even start not am I getting any spark on the plugs. I have power and it turns over though. Battery is good, fuses are good. I pulled the ignition coil to test the ohms (manual states it should @4 ohms. When I tested it was at 7 or 8 ohms. Is this variance to high and is was could be the issue? Any thoughts or suggestions?
to the forum
Your question has now been logged into the queue and the next available forum member will answer you shortly. You will be given more advice than you could hope for.
The real shortage in this country is common sense.
1 - 2 of 2 Posts
