1 - 20 of 30 Posts
So with the nice weather right around the corner, I figured I'd install some heated grips :eek: :pat: :lmao:
Actually got these Heat Demons in the bargain cave while shopping at Cabela's for some mags for my Remi 597.
I can't figure out why I didn't install these sooner. It's very simple if you do a couple tricks. The first one is using compressed air to get the old grips off. Sure I could have just cut them off, but now I have a decent set of grips leftover for potentially another use.
The second is using a nice coat of WD-40 on the bar and inside the grips to get the new ones on. Other than that, it was a breeze!!
Took it for a little 3 mile trial spin, but it's 50 here today and the trails are a muddy mess and I didn't want to tear them up too much. They are really warm, to the point where you can't hold the grip with bare hands with them on high.
I tapped the accessory power and ground:
Finished product:
I didn't get that kind, but got the Polaris version..
They get hot as hell, another great add for sure
They do heat up very well , I had a problem with the wires breaking off just where they enter the grips on the symtecs. I switched to the Tusk brand and have no complaints.
They have about 3/4" of rubber molded right into the grips where the wires enter and supports the wires. Good quality and half the price from RMATV/MC. ($55 delivered)
Wow, I just took a look at them and you're right, the molded rubber at the grip end looks to be much more sturdy. And much cheaper!
I am concerned about the lasting/quality of these symtecs, which is why I only used the tap connectors instead of tap soldering. I tried to make sure that there was zero tension on any of the wires, especially where they exit the grip and the thumb warmer. Only time will tell.
Discussion Starter #8
The compressed air in the end of the grip trick works great for getting them off and on!
Worked like a charm for getting the old ones off, but the inside of these is hard plastic so the air wouldn't work on them :motz:
Fortunately, the directions make it sound like its impossible to get them on and has several warnings about how tough it will be. They even have a warning about BRP bars which are apparently a little larger in diameter. I went very generously on the WD-40 and they slid right on.
I have symtecs on both of my machines with no complaints. The right grip on my XP is starting to wear out, those are 3 years old now
they heat up great. But I dont think they wear very good. Mine are less than a year old and are pretty worn.
Discussion Starter #11
Wow! That's not very reassuring. I hope it's just that "death grip" you put on the bars lol!
Discussion Starter #12
That's about what I was expecting out of them, 3 years or so. That's about what I get out of any grips.
Are they still as hot as when you put them on and it's just the rubber that's wearing out??
just the rubber wearing. I guess not any faster than any other grips.
Just the rubber wearing, heat still works great
Your gonna love them! Best money I spent (well tied with the winch) on my atv thus far :)
I used the wd-40 and heat gun also when I put the symtecs on and it worked great , but after about 6 months went by they started to get lose and spin on the bars.
When I put the Tusks on I heated the grips and bar with a heat gun and I used fredbears suggestion and sprayed 3m adhesive in the grip and on the bars and slid them on.
Its a little tough pushing them on but they go on. They have not moved since. I'm guessing if I need to remove them in the future the compressed air will still expand the silicone glue and they will blow off.
Discussion Starter #18
Thanks, good to know!
I dunno that 3m stuff sticks pretty good
sent from my android using tapatalk
Discussion Starter #20
That's a nice clean install.
Hey thanks! I really wanted to do a tap solder like I did when I did my 3 light mod but I figured this would be easier to remove when I need to replace them.
I think I might put in some quick connects next time so if I get a different set in the future I can just add a male end, reconnect and I'm back on the trail.
If the symtecs work well, then I will get another set and I can still use the plug they have, but if I have problems like joyrider I will be on the hunt for something different.
1 - 20 of 30 Posts
