Got the warn vantage 3000 installed with the kfi mount. It was straight forward it was nice to have the accessory posts up top front by the radiator cap to connect the postive and negative cables. I mounted the contactor box in the front storage box. I drilled 1 hole to run the wires through instead of using the drain plug hole.
Nice!!! I'm still waiting for my winch to show up. UPS delivery delay sets it back until Monday.
Dang that sucks the only pain I really had was when I innstalled it into the bracket cause It helped a lil to mount the fairing and bolt down wires and then tightened the bolts for the winch. If that makes sense.
Yep it was fairly easy to install, but still think it would look better on my 570....lol
:cowboy:
Lol and those wheels on your 570 would look alot better on mine
What did you guys use to cut the plastic section out when mounting your winch? My mounts gonna be in any day now
I didn't have to cut anything on my XP...but you might want to use a Dremel tool cutting wheel or one of these types of tools.
