As you can see, I had a pretty expensive weekend!! I would like to attempt to repair this myself if possible but i need a little help. If someone could send me the link to a video that shows how to remove/repair/re-install the front diff. or has a service manual that shows me what to do i would REALLY appreciate the help. And judging by all the other posts on the forum from guys with the same issue, I'm sure a lot more people could use the help as well!!
Judging by the pics you have a broke casting unless you know someone who can weld cast then I think you might have to buy one. Other than that it's just sticking the shafts in and filling it with fluid. Partzilla has good exploded prints if you cant find a manual. Good luck man.
i will for sure be buying one of those covers... i first have to figure out what all is broke and needs replacing. if it was just the diff cover that broke or do i need to buy a whole new diff assembly for $1500+?
As long as your internals are good, you should just need the cover.
