Hello All,
Newbie here. Just got a mint second hand 2012 Sportsman 90 for my daughter and noticed an excessive amount of lean on the front tires when we got it home and she was riding it. As she went around turns you could see the tires shift back and forth. I spoke with the dealer and read other posts here stating that this was a rollover prevention measure to lean the tires top in. I understand how that could be but is not the case here. The case here is excessive slop in the joint where the spindle is connected to the A arm. I have taken the joint apart and cleaned the grease out of it to check the fit when clean (grease will dampen the movement but not stop it so is best to check clean) and there is an enormous amount of slop and you can just wiggle a tire back and forth and feel the joint move. There is very little wear on this machine being 9 months old so is not that the A arm or spindle has worn out. Nice machined surfaces on a pretty new machine. It was made that way!
As far as safety goes. In my opinion, this would exacerbate rollover, not prevent it as I am reading and being told. If the tires were fixed at a certain angle where the geometry was controlled then I could see how it could possibly be an enhancement in certain situations. But what happens here is with the top of the tires having both tops tipped in as you ride straight and go into a turn, the outside tire flops so the top tips out and throws all the weight of the bike and rider to the outside of the turn creating conditions that I believe could lead to rollover or loss of control.
This slop on My daughters machine is limited to the spindle/A arm joint. The Inner A arm joints are nice and tight as they should be.
I have noticed another poster here with the same problem and heard it from others as well. Could it be that Polaris is making sloppy spindle joints on the new sportsman 90 because they are "safer" somehow or could they have had a bad run of parts and are putting them on the kids machines? I have never heard of a safe front end racing or otherwise that had a major amount of non adjustable camber slop in it. How can something be safe if you can't control the geometry. Please correct me If I am wrong. I certainly don't know it all but I don't feel safe with my daughter doing up to 25mph with a sloppy front end that can't be fixed because the factory made it that way. Next i was going to buy a bigger one for myself but might not choose Polaris if this is what I can expect.
So folks, what do you think? Any chance Polaris will step up to the plate and take care of this? Is anyone else experiencing this same issue that wants to chime in? Any help would be greatly appreciated!
