Is it true? And is it really that simple…
3136 Views 22 Replies 7 Participants Last post by  latebird
I heard on a YouTube video of a 500 engine rebuild guide that if you take a H.O cam and H.O carb you can turn a 500 non H.O into an H.O, question is …is it really that simple? Other then valve adjustment I’m assuming possibly a air intake mod or airbox swap.
And what about exhaust? Would that need changing or would stock work if this is possible? Also I would think you’d need a hi flo oil pump?
idk I’m new to atv engines and just curious as I have my 500 torn apart atm.
any input is appreciated, thx
1 - 20 of 23 Posts
It's easier than that - all you have to do is change the stickers
I just looked up the cam, carb, exhaust and air box for the 04 500 and 05 500 HO - they use the same parts
  • Haha
Reactions: 2
500 H.O came out in 01
The exhaust is the same, just the cam and carb are different AFAIK
OK - the 01 had a different carb and mid pipe on the exhaust - the rest of the parts were the same
The standard used a BST34 carb and the HO had a BST40 carb - by 2005 they all had the same carb
So literally just swap cam/carb , maybe a little valve adjustment and then my bike would be h.o? Lmao! Seriously good to know thanks for looking it up and confirming. I’ll be swapping those two parts for h.o for my rebuild.
got my mood up a little knowing this, considering this bike has been a downer since purchased. (Flippin scammers can’t tell the truth on fb marketplace) 😅
Cam was "updated" to to fix the wear issues of the non H.O
Sorry - cam is part number 3085855 for the following models without supersession or update:
1998 SCRAMBER 500 (W98BC50A) - Intake & Exhaust
1999 SCRAMBLER 500 (A99BG50AA) - Intake & Exhaust
2000 SCRAMBLER 500 (A00BG50AA) - Intake & Exhaust
2001 SCRAMBLER 500 2X4 (A01BA50AA) - Intake & Exhaust
2001 SCRAMBLER 500 2X4 (A01BA50AB) - Intake & Exhaust A01ba50aa
2001 SCRAMBLER 500 4X4 (A01BG50AA) - Intake & Exhaust A01bg50(Ab) (4963766376D006)
2001 SCRAMBLER 500 4X4 (A01BG50AB) - Intake & Exhaust A01bg50(Ab) (4963766376D006)
2001 SPORTSMAN 500 DUSE HO (A01CH50AF) - Intake & Exhaust A01ch50eb
2001 SPORTSMAN 500 HO (A01CH50AA) - Intake & Exhaust A01ch50eb
2001 SPORTSMAN 500 HO (A01CH50AB) - Intake & Exhaust A01ch50eb
2001 SPORTSMAN 500 HO (A01CH50AE) - Intake & Exhaust A01ch50eb
2001 SPORTSMAN 500 HO (A01CH50AK) - Intake & Exhaust A01ch50eb
2001 SPORTSMAN 500 RSE HO (A01CH50AJ) - Intake & Exhaust A01ch50eb
2001 WORKER 500 (A01CH50EB) - Intake & Exhaust
2002 SCRAMBLER 500 2X4 (A02BA50AA) - Intake & Exhaust /Ab
2002 SCRAMBLER 500 2X4 (A02BA50AB) - Intake & Exhaust A02ba50aa/Ab
2002 SCRAMBLER 500 4X4 (A02BG50AA) - Intake And Exhaust /Ac
2002 SCRAMBLER 500 4X4 FREEDOM (A02BG50AC) - Intake And Exhaust A02bg50aa/Ac
2002 SPORTSMAN 500 ALL OPTIONS (A02CH50) - Intake And Exhaust All Options
2003 SCRAMBLER 500 4X4 (A03BG50AA) - Intake And Exhaust
2003 SPORTSMAN 500 HO (A03CH50AA/AB/AC/AD/AE/AH/AJ) - Intake And Exhaust
2004 A04BG50AA SCRAMBLER 500 4X4 (A04BG50AA/FA) - Intake & Exhaust
2004 A04CH50AA SPORTSMAN 500 (A04CH50AA/AC/AE/AG) - Intake And Exhaust
2004 A04CH50AQ SPORTSMAN 500 (A04CH50AO/AQ/AR/AS/AT/AV/AW/AX) - Intake & Exhaust
2004 A04JD50AA ATP 500 4X4 (A04JD50AA/AB/CA) - Intake & Exhaust
2005 ATP 500 4X4 (A05JD50AA) - Intake & Exhaust /Ab/Ac
2005 SCRAMBLER 500 4X4 (A05BG50AA) - Intake & Exhaust /Fa
2005 SPORTSMAN 500 HO/INTL (A05MH50AB) - Intake & Exhaust /Ac/Ag/Ah/Al/At/Fb
2006 RANGER 500 4X4 EFI (R06RD50AC) - Intake & Exhaust R06rd50ab/Ac
2006 SCRAMBLER 500 4X4 (A06BG50AA) - Intake & Exhaust /Fa
2006 SPORTSMAN 450 (A06MH46AA) - Intake & Exhaust A06mh46 All Options
2006 SPORTSMAN 500 EFI (A06MH50AQ) - Intake & Exhaust /Ax/Ay/Az/Al/At
2006 SPORTSMAN 500 EFI INTL (A06MH50FC) - Intake & Exhaust
2006 SPORTSMAN 500 HO (A06MH50AA) - Intake & Exhaust /Ab/Ad/Af
2006 SPORTSMAN 500 HO INTL (A06MH50FB) - Intake & Exhaust
2006 SPORTSMAN X2 (A06MN50AU) - Intake & Exhaust /Aw
2007 RANGER 500 EFI 4X4 (R07RH50AF/AR/AT) - Engine, Intake & Exhaust
2007 SCRAMBLER 500 2X4 INTL (A07BA50FA) - Engine, Intake & Exhaust
2007 SCRAMBLER 500 4X4 (A07BG50AA/FA) - Engine, Intake & Exhaust
2007 SPORTSMAN 450 (A07MH46AA/AZ) - Engine, Intake & Exhaust
2007 SPORTSMAN 500 EFI (A07MH50AB/AL/AQ/AX/AY/AZ/MN50AF/AN/AT/AY) - Engine, Intake & Exhaust
2007 SPORTSMAN 500 EFI INTL (A07MH50FC) - Engine, Intake & Exhaust
2007 SPORTSMAN X2 500 EFI (A07TH50AL/AQ/AU/AZ/TN50AF/AS/AU) - Engine, Intake & Exhaust
2007 SPORTSMAN X2 500 EFI QUAD (A07TH50EA) - Engine, Intake & Exhaust
2008 SCRAMBLER 2X4 INTL (A08BA50FA) - Engine, Valve & Camshaft
2008 SCRAMBLER 500 4X4 (A08BG50AA) - Engine, Valve & Camshaft
2008 SCRAMBLER 500 4X4 INTL (A08BG50FA) - Engine, Valve & Camshaft
2008 SPORTSMAN 400 HO 4X4 (A08LH46AQ/AX/AZ) - Engine, Valves & Camshaft
2008 SPORTSMAN 500 EFI SCANDINAVIAN (A08MH50SS/SQ) - Engine, Valves & Camshaft
2008 SPORTSMAN 500 HO (A08MH50AX/AZ) - Engine, Valves & Camshaft
2008 SPORTSMAN 500 HO EFI (A08MN50AF/AN/AQ/AR/AS/AT/AW/AX) - Engine, Valves & Camshaft
2008 SPORTSMAN TOURING 500 EFI (A08DN50AF/AS/AW/AZ) - Engine, Valves & Camshaft
2008 SPORTSMAN TOURING 500 EFI QUAD (A08DN50EA) - Engine, Valves & Camshaft
2008 SPORTSMAN X2 500 EFI (A08TN50AT/AX/AZ) - Engine, Valves & Camshaft
2008 SPORTSMAN X2 500 EFI QUAD (A08TN50EA) - Engine, Valves & Camshaft
2009 SCRAMBLER 2X4 INTL (A09BA50FA) - Engine, Valve & Camshaft
2009 SCRAMBLER 500 4X4 (A09BG50AA) - Engine, Valve & Camshaft
2009 SCRAMBLER 500 4X4 INTL (A09BG50FA) - Engine, Valve & Camshaft
2009 SPORTSMAN 400 HO 4X4 (A09LH46AQ/AX/AZ) - Engine, Valves & Camshaft
2009 SPORTSMAN 500 EFI (A09MN50AN/AX) - Engine, Valves & Camshaft
2009 SPORTSMAN 500 EFI TRACTOR (A09MN50ET) - Engine, Valves & Camshaft
2009 SPORTSMAN 500 HO (A09MH50AS/AX/AZ) - Engine, Valves & Camshaft
2009 SPORTSMAN TOURING 500 EFI (A09DN50AB/AZ) - Engine, Valves & Camshaft
2009 SPORTSMAN TOURING 500 EFI QUAD (A09DN50EA) - Engine, Valves & Camshaft
2009 SPORTSMAN X2 500 EFI (A09TN50AX/AZ) - Engine, Valves & Camshaft
2009 SPORTSMAN X2 500 EFI QUAD (A09TN50EA) - Engine, Valves & Camshaft
2010 RANGER 4X4 400 HO (R10RH45AG/AH/AR) - Engine, Camshaft & Valves
2010 RANGER 4X4 500 EFI (R10TH50AG/AR) - Engine, Camshaft & Valves
2010 SCRAMBLER 500 4X4 (A10NG50AA) - Engine, Valve & Camshaft
2010 SCRAMBLER 500 4X4 INTL (A10NG50FA) - Engine, Valve & Camshaft
2010 SPORTSMAN 400 HO 4X4 (A10LH46AX/AZ) - Engine, Valves & Camshaft
2010 SPORTSMAN 500 EFI TRACTOR (A10MN50ET) - Engine, Valves & Camshaft
2010 SPORTSMAN 500 HO (A10MH50AJ/AX/AZ) - Engine, Valves & Camshaft
2010 SPORTSMAN 500 HO INTL (A10MH50FX/FF) - Engine, Valves & Camshaft
2010 SPORTSMAN TOURING 500 HO (A10DH50AX/AZ) - Engine, Valves & Camshaft
2010 SPORTSMAN TOURING 500 HO INTL (A10DH50FX) - Engine, Valves & Camshaft
2011 HAWKEYE 400 HO 2X4 (A11MB46FZ) - Engine, Valves & Camshaft
2011 RANGER 400 HO (R11RH45AG/AH/AR) - Engine, Camshaft & Valves
2011 SCRAMBLER 500 4X4 (A11NG50AA) - Engine, Valve & Camshaft
2011 SCRAMBLER 500 4X4 INTL (A11NG50FA) - Engine, Valve & Camshaft
2011 SPORTSMAN 400 HO 4X4 (A11MH46AX/AZ) - Engine, Valves & Camshaft
2011 SPORTSMAN 500 HO (A11MH50AX/AZ) - Engine, Valves & Camshaft
2011 SPORTSMAN FOREST 500 (A11MH50FF) - Engine, Valves & Camshaft
2011 SPORTSMAN FOREST TRACTOR 500 EFI (A11MN50ET) - Engine, Valves & Camshaft
2011 SPORTSMAN TOURING 500 HO (A11DH50AX/AZ) - Engine, Valves & Camshaft
2011 SPORTSMAN TOURING 500 HO INTL (A11DH50FX) - Engine, Valves & Camshaft
2012 HAWKEYE 400 HO 2X4 (A12MB46FZ) - Engine, Valves & Camshaft
2012 RANGER 400 4X4 (R12RH45AG/AH/AR) - Engine, Camshaft & Valves
2012 SCRAMBLER 500 4X4 (A12NG50AA) - Engine, Valve & Camshaft
2012 SCRAMBLER 500 4X4 INTL (A12NG50FA) - Engine, Valve & Camshaft
2012 SPORTSMAN 400 HO 4X4 (A12MH46AF/AX/AZ) - Engine, Valves & Camshaft
2012 SPORTSMAN 500 HO (A12MH50AD/AO/AQ/AX/AZ) - Engine, Valves & Camshaft
2012 SPORTSMAN FOREST 500 (A12MH50FF/FX/FY) - Engine, Valves & Camshaft
2012 SPORTSMAN FOREST TRACTOR 500 (A12MN50ET/EX) - Engine, Valves & Camshaft
2012 SPORTSMAN TOURING 500 HO (A12DH50AX/AZ) - Engine, Valves & Camshaft
2013 HAWKEYE 400 HO 2X4 (A13MB46FZ) - Engine, Valves & Camshaft
2013 HAWKEYE 400 HO 2X4 HD (A13MB46TH) - Engine, Valves & Camshaft
2013 RANGER 400 MIDSIZE (R13RH45AG) - Engine, Camshaft & Valves
2013 SPORTSMAN 400 HO 4X4 (A13MH46AF/AX/MS46AX) - Engine, Valves & Camshaft
2013 SPORTSMAN 500 HD (A13MH50TD) - Engine, Valves & Camshaft
2013 SPORTSMAN 500 HO (A13MH50AJ/AQ/AX/AZ) - Engine, Valves & Camshaft
2013 SPORTSMAN FOREST 500 (A13MH50FF/FJ/FU) - Engine, Valves & Camshaft
2013 SPORTSMAN FOREST TRACTOR 500 (A13MN50ET/EX) - Engine, Valves & Camshaft
2013 SPORTSMAN TOURING 500 HO (A13DH50AX/AZ) - Engine, Valves & Camshaft
2014 HAWKEYE 400 HO 2X4 HD (A14MB46TH) - Engine, Valves & Camshaft
2014 RANGER 4X4 400 (R14RH45AA) - Engine, Camshaft & Valves
2014 SPORTSMAN 400 HO 4X4/SE (A14MH46AA/AH/MS46AA) - Engine, Valves & Camshaft
2014 SPORTSMAN FOREST TRACTOR 500 (A14MN50EM/EA) - Engine, Valves & Camshaft
See less See more
Just swap the carb? The 2009 already has a BST40 carb on it - the difference is the 09 uses carb 3131567 while the 01 uses carb 3131453
Valve adjustment - that is routine maintenance and is the same for the 01 and the 09 and more
If it's on you tube it must be true - did you know that turning tires inside out will give you better traction on asphalt and make the tread last forever? I saw it on boob tube so I know it's true and I need to get one of the machines that turns tires inside out.
  • Haha
Reactions: 4
Where do you get a Hi Flo oil pump? I can't find it as a performance item on any website.
So the scrambler got the better cam before the sportsman
It's the same cam in the Scrambler - it's the same engine
No I don’t belive everything I see online wich is why I was asking here.
Reactions: 1
If it's more performance you're looking for why not simply purchase a larger displacement ATV?
Reactions: 1
Isn’t HO fuel injected.
Some were after 05 (i think). I think you could get carb or EFI untill they were discontinued in 13
I see I have an 06 HO and it’s fuel injected.
In 06 you had a choice of 500 HO with carb or not HO with EFI
In 07 all Sportsman 500's were EFI
In 08 there was 500 HO with carb and 500 HO with EFI
Reactions: 1
1 - 20 of 23 Posts
