1 - 8 of 8 Posts
There is just a hole under my headlight is that supposed to be like that? uploadfromtaptalk1396979312095.jpg
Sent from my SM-N900R4 using Tapatalk
I believe it is an air inlet for the factory snorkles on the top of your tank (under plastics)..... but not 100%.
Yeah I was wondering that's was random
if it's just a random hole in the middle of plastics that has clean edges, I think it's safe to assume that it's meant to be there. under the pod like that could be either air inlet, or a pass through for accessory wiring and such.
I've got that as well on my 850. Seems odd to me too but presume it is as intended.
Just just seems not normal okay guys thanks
No idea what its intended purpose is for in life, but I use that hole to pass my quick connect connector through for my battery tender. Keeps it mounted to the battery and accessible outside the plastics in an easy to reach spot.
1 - 8 of 8 Posts
