Im in the current market for a jet kit for my 2000 250 trailblazer... i cant seem to find the kit for it any sug. please leave link if found thanks ..:top:
take the carb apart and see what kind of main jet is in it, remove it and take it to a local shop, then go a size or so higher( maybe get the next 3-4 bigger size's, I'm guessing you want to go with a higher jetting ( larger )?
hth
Rick, Ore
dirty dawg should be able to help with this .........
What do you need a jet kit for? Jet kits are anywhere from 60.00 to a 100.00 dollars. But you can rejet your machine with oem style jets for about 25.00 dollars. I can recommend a set up if I know what you are doing with it.
