Tough lesson to learn. Never put K & N on off road vehicles. It has been discussed often on this forum. Wish I had better news but I think you are stuck with the repairs yourself.
D
D
Being unreasonable? Yes - the K&N is a performance filter and while washable and requires proper oiling, it is expected to be serviced and inspected after each use. Oil analysis is instrumental in determining the sequence of failure. Commpression rings are cast iron the cylinder is plated - the oil control ring is steel and typically the faces are plated.Now I’m not about to give in to these sons of bit$!es and just lay down! I want to be reimbursed for the repairs. Is that too much for me to ask? Am I being unreasonable?
An 850 or 1000 cannot be swapped into a 500 scrambler. Completely different engine and transmission configuration.If they accept it and reimburse me, that money will go towards a 850 or 1000 engine swap. In the meantime I guess I’ll just keep jumping through their hoops
Oh I know it’s not gonna be a simple “plug n play” swap. Gonna be some cutting and fabricating. It’ll be a project that’s for sure.An 850 or 1000 cannot be swapped into a 500 scrambler. Completely different engine and transmission configuration.
Better off fixing what you have and go OEM on parts.
D
Next time you are at the dealer, take a look at the difference between the 850, 1000 engines and yours. You would have more luck installing a turbine engine. Your 500 engine sits sideways (east and west) in the frame. The 1000 engine sits (north and south) The clutch on the 500 is attached to the crank. The clutch on the 1000 is on the transmission. The 1000 engine runs the OPPOSITE rotation of the 500. All the welding and fabrication in the world is not going to make it fit. To top it off the electronics on the 1000 and fuel systems are totally different.Oh I know it’s not gonna be a simple “plug n play” swap. Gonna be some cutting and fabricating. It’ll be a project that’s for sure.
A few years back I bought a K & N air filter for my 01 Scrambler.
So which was it? 🤷♂️The filter wasn’t a full 2 years old.
There's no way you can repair a "destroyed" engine for a "couple bucks." So which was it? 🤷♂️And I’m not too extremely worried about the outcome of my claim. I’ve already fixed it. All new parts..couple bucks. Wasn’t too too bad.
Run K&N on my Toyota truck for 15 years with no problem ? ~~Old Geez~~And I’m not too extremely worried about the outcome of my claim. I’ve already fixed it. All new parts..couple bucks. Wasn’t too too bad.
And quite frankly, only reason I put a K & N in it in the first place was because that’s the only filter anyone had on the shelf at the time. The one I had was …well…missing when I got it. Last time I actually “wanted” a K & N air filter was for my pathfinder…and turns out it ruined my mass air flow sensor right off the rip! Anyway. Thanks guys
I've been running a K&N on my 2000 F-150 since about 2003 or so, but we are talking about off-road (dusty conditions) not highway use..Run K&N on my Toyota truck for 15 years with no problem ? ~~Old Geez~~
Here is a better alternative Polaris Sportsman Air FilterI've been running a K&N on my 2000 F-150 since about 2003 or so, but we are talking about off-road (dusty conditions) not highway use..
How long have you been running a K&N in your 2003 700 Twin?
I pull my sock off and hose clamp to the intake before i ran a K&N.And I’m not too extremely worried about the outcome of my claim. I’ve already fixed it. All new parts..couple bucks. Wasn’t too too bad.
