hey guys i have an sportsman 500 efi. i have a problem going through water my atv cuts out or tends to studer. do you guys have any ideas on how i can waterproof my computer.???????????
you sure you just don't have a weak spark plug wire or other connection problem??
i thought that as well check all connectors and the spark plug and wire i also put dye elec. grease. it usualy happin when i get in deep water. i aslo notice that my compter is a little wet.....
if you git water in the computer it would be done. never run again lol first off how deep is this water your going through? and how fast are you hitting it? sounds like your sucking water into the engine.
i go into water little bit over the front dry box. i go into it slow. also when it happin i check out the air filter and it completly dry it also has that net over it to prevent water getting into the intake......
