1 - 10 of 10 Posts
well heres my problem i have a 05 sportsman 800,i just put some new exhaust studs in because they fell out well i was putting the last one in and for some reson the last one i was putting stripped out the hole,so my question is how do i fix it or do i just ree thred it and use a bigger bolt...
Not sure what bolt...I have used a heli-coil before and they are strong as hell, or can you just get a longer bolt and use a nut on the other end?
well it was the second stud in from the right side and when i say bolt i figured thats whaqt i would have to do to fix it cause i dont think i can find a bigger stud....and a heli-coil where would i get one of those and how does it work..
Heli-coil...hard to explain. If you see one it is easy to understand. Google it. But you drill out the hole with the supplied bit, you then thread in a "spring" like piece. You then thread your bolt into the spring. It is very strong, some automakers helicoil certain engine bolts from the factory.
Sent from my SCH-I510 using Tapatalk
Comes in all sizes. Those pics are just a small set I have.
1 - 10 of 10 Posts
