1 - 20 of 26 Posts
I recently installed a 12" cree led light bar. The installation wasnt bad except that I had practically 100 feet of wire to zip tie and get out of the way of everything. I noticed the light bar switch always stays lit up. Is that little light goin to drain the battery? And should I hook up a battery tender to help out?
The switch may be wired wrong. It should only light up when the light bar is on.
The light kit was plug and play. It has a red and green light to show on and off.
oh ok sorry. May want to have power come off a source that is only active when the key "on" then.
Yes it will. The question of course is, how long will that take with that little led bulb? A week? A month? 2 months? I am a big fan of keeping my snowmobiles and atv plugged into a float charger. If you run your machine often and year round, I certainly wouldn't lose any sleep over it.
My PIAA lights also have red/green light on the switch/button. Only illuminates when key ignition is on. If yours is on all the time I bet you wired it wrong.
x2, should rewire to get power from a wire that is active in ACC-mode. Typically there are two ACC wires for accessories that are up in the front of the quad under the front rack near the pod. One is orange/white stripe and the other is orange but forgot what the stripe color is; either will work for your application.
Does your winch work when the key is off?
If not tap into the hot wire for the rocker switch for your light switch.
Like others said it will likely be orange/white and under the front plastics.
Discussion Starter · #9 ·
Im not good with wiring stuff up so I guess I'll just hook thr machine up to a battery tender until I find someone that can help me out...thanks for the replies guys
looks awesome, does it affect airflow to your radiator?
I just installed a led light bar on my 13 sportsman 850. You have it wired wrong you most likely had two wires that went to the battery both most likely red that you put to positive terminal. find the one that goes from the switch to the battery and put it to key on power you probably have 3 wires with black female connectors near the battery that will be key on power i don't remember the colors but all have a mine color and a tracer color if you have heated grips its what they plug into. the connectors are on the negative terminal side of the battery.
hope this helps mine did the same thing at first then changed it once i realized i needed key on power
^ teh Key on Power wires are Orange with a White Tracer
I know it hasn't been long, but how has the Cree light bar held up,so far?
I've been looking at the rigid industries ones, but can't see myself forking out $400 for something I only use at night, and I don't ride at night often..
If you could let me know how it's been working for ya, that would be sweet!
I know it haven't been long, but how has the Cree light bar held up,so far?
The RI lights are much, much higher quality than the chi-com ebay units. Better reliability, Deutsche connectors, gor-tex vent valves, higher quality and better designed reflectors... list goes on and on.
Discussion Starter · #16 ·
The light bar has held up nicely. Put her through her paces and it held up no problems.
Been using China ebay HID's, bulbs, LED light bars, LED work lights, etc for years. The price is low enough I'll take the occasional failures comprated to spending 4x more
I picked up a 40watt light bat that is 8in across for $60 shipped on ebay. Looks like the $600 unit polaris has, but just 2 less LED's and smaller. ((the cheap china version that is 60watt was $110))
I installed one of superbrightleds.com LED light bars and the quality is excellent and if you purchase the additional LED Light Wiring Harness with Switch and relay for a extra $16.95 it made the install pretty easy.
I had to solder two wires and heat shrink the wires, drill a hole for the lighted switch and hook the red & black leads to the battery terminals. Pretty straight forward.
I did some research on LED lighting and you want at least IP67 waterproof rating or higher. The LED light link below has a IP68 rating.. The prices are excellent from these guys..
12" Heavy Duty Off Road LED Light - 72W | Off Road Light Bars | LED Work Light & Off Road LED Light Bars | Super Bright LEDs | Super Bright LEDs
Torture test
The light that gets cut with the chop saw is the light I purchased.
http://m.youtube.com/watch?v=D_Mr60MiME4
Hope any of this info helps..
Reactions: Corbett1973
hmmmm for $80-$150 I can get a 30" LED light bar for my roof rack on my SUV. OR I can spend $1200+ tax on that to get a Rigid... I'm sorry the Rigid Products are not worth 10x as much. Even if there are failures.
1 - 20 of 26 Posts
