Hey Everyone,
Wanting to do a few mods to my machine. I have a 2012 Polaris 850 XP. One of the things I was looking at are the cube LED pods for a headlight replacement. I have a couple of questions regarding this topic.
1. Where can I find a LED headlight pod adapter kit? All of the online stores seem shady or are WAY overpriced.
2. Is there a kit for the upper headlight pod?
3. Has anyone done this already and is it worth it?
Thanks!
Why not wire the lights into the high beam wire so that all 3 light come on at once. If you check 2 of those light only draw about 1.7 amps each. The headlight has a 20 amp fuse.
Hey Everyone,
Thanks!
Yeah, I saw kits and compatibility, etc. That just confused me so I just took the simple advice I found on here: Pull the stock bulbs you want to replace and run their part numbers on https://www.superbrightleds.com. Bingo, done. Prices were reasonable, shipping times fast and the replacements for pod and headlights and brakelights all worked fine.
Scott
