1 - 20 of 30 Posts
is there a lift kit for a 2013 Polaris sportsman 550 le eps
Nope does not exist.
Discussion Starter · #4 ·
I was wondering the same thing
Sent from my SAMSUNG-SGH-I747 using Tapatalk
I have seen some 550s lifted
Maybe try searching on google "2013 sportsman lift kit" and see what comes up...
Highlifter, rcd, etc there are a ton of makers. Just get off your butt and search!
Discussion Starter · #7 ·
I saw catvos make a lift
2007 500x2 le
Sp550 is on here he just ordered a highlifter kit ? He has. 550 as far as I know was arms and all bushings needed ??
Discussion Starter · #10 ·
I want a lift were I dont have to upgrade the axles
Sent from my GT-P5210 using Tapatalk
once you lift a machine you change the operating angle of the shafts....which in turn can cause pre mature wear or failure...why when you buy axels that are OEM specs..they state they are not to be used on lifted machines....
Discussion Starter · #12 ·
The catvos 2.5 lift doesn't say about upgradeing axles unlike highlifter
Discussion Starter · #13 ·
3 inch sorry
trust me, youll need them. guys break these axles with good tires in thivk mud, undermind more angle and strees on the shaft
Discussion Starter · #15 ·
Im not going muddin with it I just need a little more ground clearence
I did some research into a lift a couple months ago, if you lift it at all, you need upgraded axles, period. The OEM axles just won't stand up to the excess angle
Discussion Starter · #17 ·
Ok what would be the best axles gorillas or outlaw dhts
Gorilla and turner are #1. They are pretty much the only ones that will hold up long term being lifted.
Discussion Starter · #19 ·
What about rhinos
Rhinos are ok for non lifted quads with big tires. But they can't handle the lifted angle. Gotillas are your best bet.
Or you could always just get bigger tires with no lift to get more ground clearance. You can fit 28's no problem and 30's with minimal rubbing on the xp machines.
1 - 20 of 30 Posts
