18 Sportsman Highlifter 850
I have a outlaw fab 5 in lift and I ordered new axles all the way around. The lift instruction say to get RZR 900 S axles. I ordered Rhino 2.0’s and the fronts will not fit in the knuckle. Has anybody had this problem and is there a fix?
IDK but a lift that big I would certainly assume custom axles would be a must!!
Pretty sure that you need to trim around the knuckles with a grinder to make them fit. Others have done it, hopefully someone will speak up.
I have had the lift for a while. I used cheap axels when I got the lift, to save money on the upgrade. Now I’m just upgrading. If someone has trimmed the knuckles can you please advise me on how you did it and has the knuckle held up ok?
Just use a dremel and grind out the areas where it’s binding. 5” lift running monster tires, you might have issues with the knuckles but something else will likely break first.
