I have a 1996 Polaris Sportsman 500. I just replaced all lights on the quad.. Low beam, high beam and rear light a month ago. Now they're all blown out. I cannot figure what causing it. Does anybody have any suggestions?
I am by no means an expert. .. but I used to have a 98 back in the day. .. something I learned the hard way was. ... you had to have a battery hooked up even if it was bad. ..running machine without a battery would blow all of my lights. Not sure if this helps. .. but just something I found.
I had the same problem on my snow machine until I changed the voltage regulator
